Welcome to Club SAITO !
Old 08-22-2017, 04:49 AM
  #34501
FlyerInOKC
FlyerInOKC's Avatar
Originally Posted by Hobbsy
Jim, I couldn't find any Saito links there but may have missed it, ,maybe you can point me in the right direction, Thanks.
Here is a link: https://www.horizonhobby.com/SearchD...&storeId=10151
Select "Discontinued Only" in the drop down box in the upper right corner.
Mike
Old 08-22-2017, 07:28 AM
  #34502
the Wasp
here you go
https://www.horizonhobby.com/storefr.../saito-engines
oops sorry, I didn't post the correct link
Jim
Old 08-22-2017, 08:13 AM
  #34503
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Thanks all.
Old 08-22-2017, 07:21 PM
  #34504
the Wasp
hello o o o, any body in hear err err err, hello o o o
I guess no body is here
Old 08-23-2017, 02:45 AM
  #34505
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Rocker Cover:E,G,I,R,S,AA,EE,II,RR,AS,BM,BN,BZ,BS,CASAI5049A
According to this the rocker covers for the .50, .56 and FG 11 fit the FG 20/21 gas engines, The 1.25, 1.50 and 1.80 glow engine covers are much larger. I wonder why the gas engines have the smaller covers.
Old 08-23-2017, 03:31 AM
  #34506
Rudolph Hart
Rudolph Hart's Avatar
Originally Posted by the pope
not anymore since I got one of these
https://www.army.gov.au/our-work/equ...m1-abrams-tank
Acdc he ain't jokin buddy i'd pull the tent pegs up and skedaddle.All you got a is a no good rabbit shootin 9mm semi auto with a double stacker mag...popo is runnin round in a fully armoured abrahms tank that has a 120/6inch smoothbore target aquiring cannon...think about it,but take your time,i think his inbox is jammed.
Old 08-23-2017, 05:27 AM
  #34507
FlyerInOKC
FlyerInOKC's Avatar
I wouldn't worry too much about Pope's Abrahms I don't think he can afford the fuel to run around it too much!
Old 08-23-2017, 06:29 AM
  #34508
acdii
NO problem, I has friends with a TBF and a Dauntless. Last I checked, the Abrahms doesn't have air defenses. All good.
Old 08-23-2017, 08:42 PM
  #34509
the pope
Thats ok I have one of these in the back shed
Old 08-23-2017, 08:44 PM
  #34510
the pope
Arnt they solar powered ? I was going to put a 3s lipo in it
Old 08-24-2017, 12:10 AM
  #34511
Rudolph Hart
I'm not sure the gas engines are that different dave although i don't have a smaller gas engine to physically compare to say my 82's 115 etc.The rocker covers on my fg57 look the same as a friends fa300 twin.Any info on that fa30sc?
Popo your rich!..and careless
Old 08-24-2017, 12:16 AM
  #34512
the pope
I was going to use guinea pigs instead of live shells . More environmentally friendly that way .
Old 08-24-2017, 03:22 AM
  #34513
Rudolph Hart
Whoa! make sure you freeze the guinea pigs before firing one.Are you a commercial guinea pig breeder because those a10 gatlings fire six thousand guinea pigs a minute.What did you feed them before firing them at who knows what,the questions could go on and on and i'm stressed,any saito questions?
Old 08-24-2017, 03:31 AM
  #34514
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Pete, I don't have all those engines to,compare, my only gas engine is the FG 11.I have some extra rocker covers to compare for a 1.50, a .30 and maybe an .82. I'll line em up as best as I can I'll identify them.
Old 08-24-2017, 04:15 AM
  #34515
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
R C Specialties Turbo Headers get mentioned quite often in this Saito thread, here is a link to an excellent review of this quality product.
RC Specialties Turbo Header Muffler and right angle
Old 08-24-2017, 05:51 AM
  #34516
FlyerInOKC
FlyerInOKC's Avatar
Maybe if you added a few solar panels on top but I would think you would need at least a 4s or 5s.
Old 08-24-2017, 06:00 AM
  #34517
acdii
Old 08-24-2017, 06:03 AM
  #34518
acdii
I think that Saito is using the off the shelf approach on many of their engines designs. Why make individual rocker covers for each engine when they can make 3 or 4 covers for the entire line. Same probably holds true for many of the replacement parts. If they keep the length of tube and pushrods the same between different displacement by enlarging the bore, and keeping the cylinder the same height off the crank, then those are fewer parts to stock.
Old 08-24-2017, 06:18 AM
  #34519
acdii
Hey Pope, this guy does NOT approve of your ammo selection
Old 08-24-2017, 01:20 PM
  #34520
the pope
cabbage or brussle sprouts
Old 08-25-2017, 03:30 AM
  #34521
Rudolph Hart
Is the fg11 the old fa62? if so that engine was a cracker and what are you going to fly it in?
Sorry popo did'nt know you were going fully organic on the guinea pig firing,cabbage and brussells sprouts,a lot of gas but what greeny inspired ignition system do you plan on using.There can't be a grown man that,at some party somewhere,has watched a mate bend over and flick a bic lighter and huge flames and thought...i can do that. ps sorry to hear you are now using a grey graupner 12x6 prop to peak your saito 125.Could you run more than 35% nitro safely do you think? aaah mate i'm feelin your pain
Old 08-25-2017, 03:38 AM
  #34522
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Is the fg11 the old fa62? if so that engine was a cracker and what are you going to fly it in? (quote)
Yes the FG 11 is 62 B based with an increased bore from 26.2mm to 27mm making it a .66. Horizon actually has the wrong picture accompanying the .62-B, #2 is correct.
ID:	2229342   Click image for larger version
Old 08-25-2017, 04:11 AM
  #34523
N1EDM
Hello Great and Powerful Saito-Heads. I need your sage advice! I.e., how about a method for Cleaning valves...
I'm rebuilding an old FA-65 for a friend and the compression 'could be better'. The engine was run very rich but I've cleaned a lot of that old burnt castor out and am going to test run the engine today. But I feel that the valves may need to be removed and cleaned and/or lapped.
I've used the old Bon Ami paste method with limited results. Does anyone else have a clever idea for getting the crud off of the valves?? Could I perhaps inject something like WD-40 down the intake while the engine is running?? Something like that???
Bob
Old 08-25-2017, 06:54 AM
  #34524
acdii
Have you tried soaking it in denatured alcohol? I have been able to clean a lot of old grimy castor soaked engines that were seized up with it.
Old 08-25-2017, 06:57 AM
  #34525
FlyerInOKC
FlyerInOKC's Avatar
I usually bake castor oil soaked engines at 250 F for 20 to 30 minutes and then the stuff wipes off. I then hit the engine heavy with after run oil (Marvel Mystery Oil for pneumatic tools).
