Welcome to Club SAITO !
Old 03-12-2018, 01:25 PM
  #35776
demetrisrc
Wasp I owned this plane with exactly the same setup. It was a dream to fly and sounded so nice. Unfortunately I lost it last year due to an engine cut...
I have another 2 Saito 90twins brand new in their boxes if anybody is interested.
Old 03-12-2018, 02:03 PM
  #35777
BarracudaHockey
BarracudaHockey's Avatar
Please keep buying/selling to the marketplace or private messages
Old 03-13-2018, 03:50 AM
  #35778
Rudolph Hart
Rudolph Hart's Avatar
Originally Posted by Hobbsy
Saito FA-65 (2)
The old/new Saito .65 is supposed to arrive tomorrow, that's fast service. It has been said that the hump in the middle of the piston is for higher compression. Clarence Lee says it is to clear the upper rod end.
Well you could slide the crank out then hold the piston and rod assy up and look in there,maybe take a photo and let us know what you see.Is it a high compression bump or not?
Went for a quick ride last sunday down south to watch the vintage motorcycles racing at collie.Here's a pic of us on the way down.First person who say's that old fart on the black ducati looks like the slowest is deaded
Old 03-13-2018, 03:59 AM
  #35779
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Good morning Pete, the bump is clearly visible through the glow plug hole, but it does have 12.7 to 1 compression, whether that's because of the bump, I don't know. Clarence Lee said it was not a fussy engine. I'll see if I can get that shot you mentioned.
Old 03-13-2018, 05:27 AM
  #35780
FlyerInOKC
FlyerInOKC's Avatar
I figured you were the Fastest. First one there parks the closest to the building and beats the other old farts to the water closet!
Old 03-13-2018, 05:44 AM
  #35781
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Picture #1 shows the carb metering slot and the fuel inlet with which it indexes. Picture #2 shows the edge of the bump in the center of the piston. The bump allows the rod to be longer reducing rod angularity which in turn reduces side thrust and friction. According to Clarence lee.
Name:	Saito 65 Carb meter slot.JPG
ID:	2259065   Click image for larger version
Name:	Saito 65 piston bump.JPG
Old 03-13-2018, 07:08 AM
  #35782
the Wasp
Dave, just a thought here, you know the way these Glow engine manufacturers in this hobby can be, well, maybe Saito made that "High Compression" engine for 0% Nitro for the European market, and yet they found it ran so well on 10% & 15% they decided to sell it inside the USA,, just a thought
hey OF, I have been on the Saito site a while now, and I now, do have 2 Saitos, I was wondering if I yet have earned a high enough rank here whereby I can call you Pete ??, after all, Old Fart & OF is not that respectful
Jim
Old 03-13-2018, 07:36 AM
  #35783
FlyerInOKC
FlyerInOKC's Avatar
Jim
Hey he worked very hard to earn the right to be called "Old Fart" it took a lifetime to earn that moniker!
Old 03-13-2018, 07:37 AM
  #35784
acdii
He's Aussie, they live for that !
Old 03-13-2018, 09:37 AM
  #35785
the Wasp
I did not know that
LOL
Jim
Old 03-13-2018, 10:31 AM
  #35786
FlyerInOKC
FlyerInOKC's Avatar
Its a progression, he started out as a Young Fart, then became a Worthless Fart, and then after years of experience worked his way up to Old Fart!
Old 03-13-2018, 11:40 AM
  #35787
the Wasp
what will he be in 5 years ?
maybe you better not answer that !!!!
Jim
Old 03-13-2018, 11:50 AM
  #35788
FlyerInOKC
FlyerInOKC's Avatar
Jim
5 years more ripened! Be afraid, be very afraid!! :0
Old 03-13-2018, 01:55 PM
  #35789
acdii
Killer Fart, silent but Deadly.
Old 03-13-2018, 03:24 PM
  #35790
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I had mentioned that I made the velocity stack on the new .65 and here you see how I did it. The 1/4" drive 3/16" socket is a snug fit into the 9mm OD H&S tube and that's good so the socket can't wobble around and make the flair lopsided. The O-ring makes it require some pressure to push the clip up onto the carb. All this one needs is for the other end to be flaired. It's just a piece of scrap though. The brass tube ones are better looking, I think.I use 9.5mm tube for the 1.00 and 1.25 Saito's
ID:	2259136   Click image for larger version
Old 03-14-2018, 03:14 AM
  #35791
Rudolph Hart
Nicely made intake tube and a pic of the throttle barrel?
Okc i was on a shooting trip way back and we'd had a big night on the beer.On the way to the shooting spot in the morning there were six of us crammed into a ford marquis luxury saloon when the silent and deady came into effect.People started yelling 'pull over' the car was empty before it came to a full stop.
Old 03-14-2018, 03:23 AM
  #35792
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Like this one? Thanks
Old 03-14-2018, 05:05 AM
  #35793
FlyerInOKC
FlyerInOKC's Avatar
The star of many a Quin Martin production!
Old 03-14-2018, 05:38 AM
  #35794
acdii
Well, been trying to post the submarine scene with the really bad fart, but keep getting database errors.
https//www.youtube.com/watch?v=Ie0L0EIWR4A
Old 03-14-2018, 07:38 PM
  #35795
the Wasp
last night that happened to me too on the Saito page, I will try again
Jim
Old 03-14-2018, 07:42 PM
  #35796
the Wasp
put put put put put a Saito 100T & 90T burning Gas, stock Carbs, very cool put put put put put put
Old 03-15-2018, 04:59 AM
  #35797
FlyerInOKC
FlyerInOKC's Avatar
Maybe that explains the loss of that sub off the coast of South America?
Old 03-15-2018, 07:12 AM
  #35798
the Wasp
^lol^
Old 03-15-2018, 08:44 AM
  #35799
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
OK Gents, I finally got/took the opportunity to run the rebuilt Saito 1.30-T, I did not prime it, it took it about 3 seconds to pull fuel out of the Roto Flow 14 oz tank and it fired right up. It was way rich, I pretty much did my usual break in considering that it had a new piston and ring in the right cylinder and a new ring in the left and four new valves,, cams, lifters, springs, keeper's etc. After about 25 minutes I stopped it and turned each LS needle in 3/4 of a turn, it will idle at 2,500 without dropping a cylinder. I need to work on the linkage before I can go lower than that.
Saito 1.30 T rebuilt
Prop======Master Airscrew 15x8 S2
Plugss=== (4) OS-f
Fuel =====Wildcat 10% with 18% full synthetic
Exhaust===two Saito 65/82 revised mufflers.
Max rpm @ close to full peak==9,120, Clarence Lee got 8,700 with a Zinger 15x8
There are too many things going on to run it longer, another 30 minutes and then I'll go for full peak.
No picture of it running yet.
ID:	2259306   Click image for larger version
Old 03-15-2018, 03:46 PM
  #35800
acdii
Wish I had time to run up my engines. I have 4 that need to be run in, two new NGH 38CC 4 stroke gas, and two used YS engines that I have sitting around. I also have the Saito 91 in the new 4*60 that hasn't been run for years and was given to me. Should fire right up, but wont know until I get it on the stand. Really eager to hear how those 38CC engines sound with a stack. They are going in my B-25.
