Welcome to Club SAITO !
Old 10-23-2005, 05:07 PM
  #601
rfan_1
Default RE: Welcome to Club SAITO !
Hello,
I have a 180 GK and 2 100 Saitos. My question is: On an Ultra Stick 120, the 180 will be mounted sideways, whick puts the needle valve perpendicular in relation to the tank. Should the tank be mounted as high as possible right behind the firewall, or is it not an issue, considering how close it is to the engine?
Thank you for your time.
RFan
Old 10-23-2005, 05:22 PM
  #602
William Robison
rfan_1:
The US 120 is just fine as delivered with your Saito side mounted. Here's a couple pics of mine - yes, it's the older, heavy version.
Bill.
ID:	342992   Click image for larger version
Old 10-23-2005, 05:40 PM
  #603
rfan_1
Thanks, Bill for the quick reply. I'm putting the 120 lite version together and the instruction manual must be for the older version, since a lot of the pictures don't quite match what I have. For instance, the throttle cable hole in the firewall won't even work where they show it should be. Did you use the rod that was supplied, or switch to a cable?
RFan
Old 10-23-2005, 05:48 PM
  #604
William Robison
rfan_1:
Look more closely at the second picture above. The throttle rod comes out the side of the fuselage under the rear end of the "Hangar9" sign. Here's another picture giving a better view - yes, it uses a ball end.
Bill.
Old 10-23-2005, 06:30 PM
  #605
rfan_1
Ahhh... now THAT throttle setup will do nicely. Thanks again, Bill!
RFan
Old 10-23-2005, 06:58 PM
  #606
desmobob
I have a Saito question, club guys.
What is an appropriate size fuel tank for a 1.50 running in a 1/4-scale Giles 202? I forgot to keep track of fuel consumption when I had it on the break-in stand. I like to fly for about 10-12 minutes with enough reserve for a couple of circuits if necessary. 16 oz? 18 oz? I have a 20-oz. tank but it just looks TOO BIG...
Thanks for any suggestions,
desmobob
Old 10-23-2005, 07:11 PM
  #607
William Robison
Bob:
Rule of thumb for a Saito on 15% fuel is one ounce per minute per cubic inch at full throttle. So your FA-150 will have an approximate fuel rate of 1.5 ounces per minute at full power. At lower power settings the rate will be lower.
In "Normal" sport flying a 12 ounce tank should give your ten minutes with a margin. If you usually run at a higher setting increase the tank size accordingly. I see no way you would not be able to get your ten minutes from a sixteen ounce tank regardless.
You wont get your fuel rate this low unless the engine is adjusted properly.
Bill.
Old 10-23-2005, 07:36 PM
  #608
desmobob
ORIGINAL: William Robison
Bob:
Bill.
Thanks Bill. You're always a wealth of good information. (I really enjoyed your post on the AAC construction. We used to have a Chevy Vega when I was a teenager.) I was thinking along the lines of one ounce per minute, but that would have had me a little short!
I think I'll play it safe and install a 16 ounce tank.
Good flying,
desmobob
Old 10-23-2005, 08:18 PM
  #609
swede-RCU
Hello all in the Saito club-
I'm putting a Saito 100 on an Ultra Stick .60 and wondering what might be a good prop for the crow and hovering. Any recommendations?
Swede
Old 10-23-2005, 08:30 PM
  #610
proptop
My Feedback: (8)
proptop's Avatar
swede...a 15x4W or 16x4W APC would be a good choice...depending on what nitro % fuel you intend to use.
Old 10-23-2005, 09:00 PM
  #611
swede-RCU
Thanks proptop-
I'm just using Sig 10%nitro, 20% oil-1/2 castor/-1/2 syn. It's always worked good for my 2 and 4 stroke engines.
Swede
Old 10-23-2005, 09:53 PM
  #612
Timthetoolman1
Timthetoolman1's Avatar
Tim:
Still sounds like the top end (HS needle) is lean. The LS could be too, but if it idles nicely and answers the throttle cleanly it wont be too far lean.
As I said, iopen the HS a bit and try it, then a bit more, etc. If it wont go to full, and it's not blubbering, just about has to be lean. You might also check the fuel hoses and ports, be sure there's not some small bits or leaks there.
Bill.
It's fine, this is my first cool weather since I started flying, so tuning must be a little difference.
I just got a Saito 1.20 that has had 2 liters through it, I'm thinking I need to keep it rich for at least another 3/4 gallons, right?
Old 10-23-2005, 10:25 PM
  #613
William Robison
Tim:
There's no set amount of fuel to run the engine in. Some will be ready to fly quickly, others will take longer.
With the engine running on the stand take it to full throttle, lean it to peak. Have your finger ready to chop the throttle. If the engine will hold peak rpm for 30-40 seconds without sagging it's ready to fly.
When you fly it don't hold full throttle for too long at a time, and when setting the HS needle instead of the 100-200 rpm rich drop, give it at least 400 rpm.
As you continue to fly the engine you can slowly work your way to the 200 rpm drop, you can judge the time by the idle settings. When you get the reliable 2000 rpm or so idle, the engine should be ready to go. I don't recall one that wasn't ready to scream with an hour to an hour and a half on it.
Even then, the engine isn't as good as it will be after four or five hours, it will just keep getting better.
Do check the valve clearance every 1/2 hour or so for the first couple hours. once you find it's holding steady you can increase the interval. Still not a bad idea to pull the rocker covers before each flight session and douse the rockers with oil. Use your after run oil, it works fine.
Bill.
Old 10-24-2005, 07:02 PM
  #614
iflynething
Much information William, I like the one on the AAC stuff, or the longevity and how everythings made.
If the 100 was plenty power for the 90 Funtana then the 125 will be amazing, and I can't imagine one with a 180!
Oh, the 100 that was on my Funtana, the wings folded on the plane. I was doing a snap at less then 1/4 throttle and the left wing came off right at the first spar after the sheeting. Anyone else had thsis problem? I'm sending plane back to Hangar 9 hopefully for a replacement.
The fuse went strait in, but I couldn't tell of any damage to the engine. I just took a a toothbrush and cleaned the fins and everything inbetween. As far as any other damage, I can't tell of a bent shaft or anything. I'll see when I hopefully put the 100 on a Funtana #2 from Hangar 9. I don't know how this happened, not from stress, I WAS ONLY at 1/4 throttle.
I still love that Saito though!
~Michael~
Old 10-24-2005, 10:05 PM
  #615
William Robison
All:
Well, folks, I was intending to cut off the numbers at 100, and that was rfan_1. Then, before I put him on the list and announdec a stop to it, along came swede-RCU as number 101 on the list.
Guess we'll just have to keep going for a while. The complete up-to-date lists are still on page 4 of this thread. Or if you just want an easy jump click [link=http://www.rcuniverse.com/forum/m_3306814/anchors_3338246/mpage_4/key_/anchor/tm.htm#3338246]here[/link] to see them, scroll down a little way.
Let's all give a nice welcome to:
#100 rfan_1
#101 swede-RCU
Bill.
Old 10-25-2005, 08:21 AM
  #616
Edwin
Well cr@p. Busted the pressure nipple on the muffler last weekend. From the research it looks like saito doesnt sell the individual pressure tap, true? The reason I wanted a saito replacement is because I will eventually use this saito 1.20 and the other three I have on a four engine bomber. The dubro's I see have a MUCH smaller diameter hole for the tap. Is that going to change the head pressure enough to make a difference between the engines? Is the hole size a non-issue and should I just change all of the engines to use the same aftermarket pressure tap? And no, I dont want to use a fuel pump, saito's dont need them.
Edwin
Old 10-25-2005, 11:08 AM
  #617
w8ye
My Feedback: (16)
w8ye's Avatar
Saito sells several different pressure nipples...
http://www.horizonhobby.com/Search/D...hType=Standard
Old 10-25-2005, 11:23 AM
  #618
Edwin
I looked at those. Im at work right now and dont have the parts breakdown for a 1.20. I was interpretting the breather nipple as the crank case vent. Are those the same? And is there a parts breakdown diagram on line?
Edwin
Old 10-25-2005, 11:29 AM
  #619
w8ye
My Feedback: (16)
w8ye's Avatar
Saito 120 manual...
http://www.horizonhobby.com/ProdInfo...der_Manual.pdf
Old style Saito muffler...
http://www.horizonhobby.com/Shop/ByC...dID=SAI120S74B
New style muffler...
http://www.horizonhobby.com/Shop/ByC...dID=SAI120S74D
I've been looking at my 150 and 100 engines. The muffler nipple is the same as the carb nipple but you cannot get the nipple for the 120 without buying the whole spray bar assm. so here is a carb nipple for a 100 ...
http://www.horizonhobby.com/Shop/ByC...dID=SAI100T147
Old 10-25-2005, 02:14 PM
  #620
iflynething
Why would you want to stop at ONLY 100?
~Michael~
Old 10-25-2005, 02:37 PM
  #621
William Robison
Michael:
ORIGINAL: iflynething
Getting tired of keeping the record. Anybody else want the job? I'll send you the Excel file.
For the moment I'll continue.
Bill.
Old 10-25-2005, 03:20 PM
  #622
iflynething
Oh, ok, didn't think about that. 100 is alot of people, but I'm not sure how to work that Excel file and do everything necessary to add and repost on this thread, anyone else want to take the job?
~Michael~
Old 10-25-2005, 06:02 PM
  #623
SuperSmoker
SuperSmoker's Avatar
i lub my saito!!
Old 10-28-2005, 06:20 PM
  #624
Chrille
Chrille's Avatar
Hello Everyone Need some good advice !
My new Saito FA 300TL suffer from a hard contact with terra firma. Crank is bent and the valve-guide for intake and exhaust is also bent ( right side cylinder) what to do to get it straight
Old 10-29-2005, 01:55 PM
  #625
Kmot
My Feedback: (24)
Kmot's Avatar
Well, shoot! I have not been around the engine forum for awhile and I missed the charter membership! []
Anyway, I have a Saito .40 Mk. I open rocker box I bought new back in the 70's. I have a Saito .45 Mk II I got used and a Saito 120 Mk I NIB I got from Meesh.
