Welcome to Club SAITO !
Old 01-21-2008, 08:06 PM
  #9726
Ken6PPC
Default RE: Welcome to Club SAITO !
The spinner nut in the picture above is a Higley.
http://search.horizonhobby.com/index...d=1179F075EA00
Old 01-21-2008, 08:25 PM
  #9727
decoy26
Hey thank you for all the info guys! It makes sense and they have those at the LHS so I will pick one up tomorrow. Thanks again!
Old 01-21-2008, 09:58 PM
  #9728
slong
Have any of you ran a Saito 180? I am looking for a good 3-D APC prop recomendation for a 10-12 pound airplane
Old 01-21-2008, 11:08 PM
  #9729
Jerryballs
My Feedback: (19)
BLW,
Three years in the hobby now...I learned with a 72, currently have two 100's, three 180's, a 91, and a 150. All great engines...should have a number?
Jerryballs
Old 01-22-2008, 12:41 AM
  #9730
AKFireMedic
AKFireMedic's Avatar
ORIGINAL: Ken6PPC
Be sure to note that Higley sells heavy (brass) and lightweight (aluminum) thin lock nuts so get the one that best suits your needs.
Old 01-22-2008, 12:45 AM
  #9731
AKFireMedic
ORIGINAL: w8ye
Tru Turn sells a special nut - washer set for this situation
http://www.truturn.com/cgi-bin/store...dapt0717a0716a
http://www.tru-turn.com/af.htm
I would do everything I could to aviod that particular TT adaptor. It requires you to ream the inside hub of your prop to a whopping 1/2"!! I ended up with a mix of Tru-Turn and Dave brown parts on my 82 to make the TT spinner work without using that horrible TT adaptor. The important thing is that you have 2 nuts holding the prop on and that the spinner screw adaptor is threaded correctly for the screw you want to use.
Old 01-22-2008, 08:30 AM
  #9732
Capt Lou
Michaelh:
Thanks for the suggestion. I have not used Omega fuel as I'm satisfied with the power of the Cool Power 30% heli. What I plan to do is put 2 ounces of castor oil in the gallon of fuel.
Old 01-22-2008, 08:51 AM
  #9733
Capt Lou
I use spinner nuts on all my Saito engines. The Harry Higley product comes in both heavy duty brass and light aluminum, depending on the weight requirements and balance of you plane. They also make spacer nuts that will take care of your problem. These nuts are nice and work real well. I have given up on plastic spinners as they fail too often and the big aluminum spinners are expensive and require adapters. Dubro also makes a spinner nut that is conical shaped and looks good on the plane. I put this on my Saito 91 and it looks nice and fuctions well. Also, you should change your electric starter insert to one that is made for a spinner nut. While this is an additional cost, in the long run you'll be glad you did it because the insert will grip the spinner nut much better, make it easier to start and is safer.
Old 01-22-2008, 08:54 AM
  #9734
blw
blw's Avatar
Glad you guys are hanging around here.
565 brockettman
566 colecaz
567 slong
568 Jerryballs
Old 01-22-2008, 09:27 AM
  #9735
colecaz
Glad to find this great thread and be a part.
Cole
Club Saito Member 566
Old 01-22-2008, 03:19 PM
  #9736
boogermancan
boogermancan's Avatar
a spinner nut is oh so nice its got a hole in it to use a small screw driver through the hole and tighten down prop how ever i have never used one with a wooden prop
Old 01-22-2008, 05:11 PM
  #9737
1rcaddict
I removed the carburator on my FA-82 and noticed some type of orange sealant has been used in addition to the "o" ring at the intake manifold. What is it, and is it necessary?
Old 01-22-2008, 07:45 PM
  #9738
Geardaddys
Fuel question for you fellas..
Have a new Saito 125 (first 4 stroke).. My LHS sells Byron Fuel.. Bought a few gallons of "Traditional Sport Premium?" I think it was called.. Anyway, it was 20 percent oil and 10 percent nitro.. Advertised as a blend of castor and synthetic.. will this fuel be good a least for breaking in? The hobby shop dude tried to talk me into a lower oil content, but the Saito manual is pretty clear on using at least 20 percent.. I'm not sure how much castor is in this fuel and Byron doesn't seem to respond to email.. (chumps).. Anyway, thanks for your opinions!
John..
Old 01-22-2008, 07:48 PM
  #9739
Ken6PPC
ORIGINAL: colecaz
Cole
We are glad to have you join us!
Old 01-22-2008, 07:51 PM
  #9740
Ken6PPC
ORIGINAL: 1rcaddict
Could that be some RTV sealant that someone else used on it before you got it?
I have never seen any orange sealant from the factory on any of my Saitos.
Old 01-22-2008, 07:52 PM
  #9741
w8ye
My Feedback: (16)
w8ye's Avatar
Me niether
Old 01-22-2008, 07:55 PM
  #9742
Ken6PPC
ORIGINAL: Geardaddys
John..
I don't think anyone but Wildcat will tell you exactly what is in their fuel. I normally use 15% nitro Wildcat Premium Xtra. It has 18% total oil, in an 80/20 blend of synthetic/castor oil. http://www.wildcatfuels.com/container.html
I think the fuel you bought will be fine. I haven't used Byron's, but I have never heard anything bad about it.
Old 01-22-2008, 08:11 PM
  #9743
1rcaddict
It looks like RTV but i'm not sure, I thought I read an earlier post from Bill Robinson that mentioned sealing the intake manifold but he could of been talking about something else.
Maybe I should order a new "O" ring and gasket, what do you think?
Old 01-22-2008, 08:23 PM
  #9744
Ken6PPC
If it isn't leaking, why "fix" it? Naturally, a new O ring and gasket won't hurt anything.
It is possible that someone used RTV sealant in that area, trying to prevent a potential problem.
Some of the earlier plastic backplates were prone to warpage and loosening, and causing a leak in that critical manifold connection to the cylinder. You can tell if your backplate is one of those with that potential by checking it against these two photos. (originally posted by the late Bill Robinson, IIRC) The second one is the one you want. It has reinforcing ribs where the carb mounts to it, and it works well.
Look at where the carb bolts onto your backing plate, and see if you have the two little ribs that you see in the second photo. If you don't, you might want to get a new backplate. http://www.horizonhobby.com/Products...rodID=SAI7217A
On the other hand, if you don't have a leak, this is all much ado about nothing!
ID:	858443   Click image for larger version
Old 01-22-2008, 08:44 PM
  #9745
1rcaddict
Thanks for the reply although i'm new to this site and to Saito, I just love the motors. Having read so much on this thread that was posted by Bill Robinson I just assumed he was still around, Sorry. I checked the back plate, and it is the improved version. I guess now I just wonder why the RTV was there and if I should use it again. Maybe a little extra protection couldn't hurt. By the way should there be any kind of a seal or gasket where the backplate meets the case?
Old 01-22-2008, 10:04 PM
  #9746
Ken6PPC
EVERYONE here misses Bill Robinson. I didn't know him well, as many on this board did, but his writings made me FEEL like I know him. We exchanged a few emails and PM's, but not that much.
There is no gasket between the rear cover and the crankcase on the 82. I don't blame you for being surprised by that - I was too! Other Saitos with metal rear covers DO have a gasket in this area. I suppose the plastic cover seals well enough without it.
I doubt the RTV sealant could hurt anything, except perhaps the looks.
Old 01-22-2008, 10:12 PM
  #9747
1rcaddict
This site is a great resource for all of us that love this hobby and especially our Saitos, thanks for the help.
Old 01-22-2008, 10:56 PM
  #9748
brockettman
brockettman's Avatar
Thanks for lettin' me in the club! Looking forward to some more great info....
Ben
Club Saito Member #565
Old 01-23-2008, 07:20 AM
  #9749
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
1rc, some guys are paranoid and put the stuff everywhere, it's rarely actually needed, folks just need to relax, run their engines and enjoy them. 99.99% of engine troubles are the the needle settings not mechanical faults.
Old 01-23-2008, 07:24 AM
  #9750
BountyHunter51
BountyHunter51's Avatar
Hey guys,
I just stumbled across this thread and have to say that there is a huge amont of info to be found here (glad I found it). I just picked up a Saito FA100 that is destined for my 84" Cub (under construction). This is my first Saito engine so I'll *humbly* ask for admission to the club.
I'll be breaking in this little gem soon and can hardly wait to get it in my plane. Thanks for all of the great info!
Cheers! BH
