Welcome to Club SAITO !
Old 07-22-2010, 03:56 PM
  #17951
shaggy48
Default RE: Welcome to Club SAITO !
Is this the longest running thread on RCU?
Do I qualify to join?
Only 2 saitos a fa 100 and a 56
Shaggy
Old 07-22-2010, 04:05 PM
  #17952
w8ye
My Feedback: (16)
w8ye's Avatar
ORIGINAL: Tom Jones
Hobbsy, Is Lynda your wife? Hope she is getting better. My Prayers are with her for a complete recovery, God willing. Take care Tom
Linda is Hobbsy's middle aged daughter who has had several recent health problems and has been forced to live with Hobbsy and his wife
I've called his home but didn't get an answer.
Old 07-22-2010, 07:46 PM
  #17953
SRQFlyer
My Feedback: (17)
SRQFlyer's Avatar
Hi all,
Finally getting around to ask about joining the CLUB. I have a 30, 50, 56, 72, 82, 91, 100, (2) 120 dual plug pumpers, (2) 150s. I fix engines for the guys here in Sarasota and probably have had another 50 Saitos apart. I love all my Saitos - the 50 and 91 have more hours on them than I can count. Several sets of bearings for each, but both have the original ring!
Jim
Old 07-23-2010, 05:53 AM
  #17954
on_your_six
I am hereby requesting membership into your fine organization... I am the proud owner of a 125 golden knight, a 120 and a FS90TS twin. I am hoping that the membership dues are not substantial. Does the initiation ceremony involve hazing?
I am looking for some exhaust pipes for the FS90TS... anyone got something laying around?
Old 07-23-2010, 08:18 AM
  #17955
Cherokee Flyer
You will get hazed if you are a member or not!!!
696
Old 07-23-2010, 09:26 AM
  #17956
blw
blw's Avatar
ORIGINAL: on_your_six
Yes, you have to send me one Saito engine in order to be a club member in good standing. Right now, I need a good .91.
697 ZachB10
698 shaggy48
699 SRQFlyer
700 on_your_six
I would put #700 in my sig line if it were me!
Old 07-23-2010, 11:45 AM
  #17957
on_your_six
Fantastice, the engine is in the mail...
Hey I am double ought seven backwards ... das ist cool!
On_Your_Six now 700
Old 07-23-2010, 11:53 AM
  #17958
chunkyplunker
chunkyplunker's Avatar
Double ought seven could stand for wins ties losses. I think I'd stick to 700 just in case.
Cherokee flyer, let the hazing begin.
Old 07-23-2010, 08:00 PM
  #17959
Cherokee Flyer
That will happen without any help from me!!
Old 07-24-2010, 06:16 AM
  #17960
Rudolph Hart
Rudolph Hart's Avatar
ORIGINAL: Hobbsy
Jim, here's the .30 arrangement.
Jim et al, Lynda is back in the hospital, one of her kidneys stopped working and loaded her up with uric acid causing violent convulsions and near comotose. They got here awake yesterday but she is still very weak.
Sincerely good luck dave
Old 07-24-2010, 06:21 AM
  #17961
Rudolph Hart
ORIGINAL: w8ye
I've had a Saito 82A about 4 yrs. I decided to make a 82B out of it.
I bought
Back plate
Crankcase
Cam cover
Carb screw set
Cam pivot shaft
I had to steal a cam cover gasket from my Saito FG20 collection and I had to make a gasket for the back plate as Horizon doesn't have gaskets yet.
I made the back plate gasket from the cover flap of the package that the back plate came in. I cut the inside circle and slipped it over the back plate and then mounted the back plate and trimed off the outside. You need a gasket back there to keep the cam cover from rubbing on the crankshaft pin.
After getting it together I ran the engine on the test bench and it runs just as good as it did before I changed everything.
I like your sense of humour friend.Caqn we get a 100 or 125 cylinder on an 82a which already equals the old 91 in performance or am i dreaming a bit?
Old 07-24-2010, 07:50 AM
  #17962
w8ye
My Feedback: (16)
w8ye's Avatar
ORIGINAL: Old Fart
ORIGINAL: w8ye
I bought
Back plate
Crankcase
Cam cover
Carb screw set
Cam pivot shaft
I've been thinking about this. The 82 already has a 100 piston. You could bolt on a 100 cylinder, shorten a 100 intake manifold and mount a 100 carb to replace the 91 carb that's already on the 82. You also should use a 91/100 muffler instead of the 65 muffler that comes on a 82.
The cylinder that comes on a 82 has the same bore as the 100 cylinder but uses 91 valves.
Using a 125 cylinder would complicate things as you would have to use the 125 piston and then what about rod length?
Old 07-24-2010, 09:40 PM
  #17963
mistermnkim
My Feedback: (153)
mistermnkim's Avatar
hey anyone started their saito single backwards? i had my starter reversed at the field today and started my 56 in reverse, i flew the plane several times after with no problems think i did ant harm?
Old 07-24-2010, 09:54 PM
  #17964
w8ye
My Feedback: (16)
w8ye's Avatar
Apparently not?
Old 07-24-2010, 09:57 PM
  #17965
shaggy48
while retuning my 100 it ran backwards for about a minute
I had trouble shutting it down. Don't think it caused any harm
And is usually just improper tuning. Usually too rich
Old 07-24-2010, 10:10 PM
  #17966
w8ye
My Feedback: (16)
w8ye's Avatar
It is running off fuel in the muffler
Old 07-24-2010, 10:30 PM
  #17967
mistermnkim
My Feedback: (153)
well just thought i would check, w8ye? apparently not was not the response i was expecting? something like no it should be fine, or you might want to check a push rod or something else. this is the only saito i own so i dont know the ins and outs of them so i come to you guys. mark
Old 07-24-2010, 10:33 PM
  #17968
w8ye
My Feedback: (16)
w8ye's Avatar
You didn't hurt it. It will be fine
Worst case scenario is that it would mess up the o ring where the intake manifold goes into the head but if it ran afterwards, there is no problem
Old 07-24-2010, 10:40 PM
  #17969
mistermnkim
My Feedback: (153)
ok pal thanks!! i feel much better about it now, it runs so good i was scared i had hurt it, thanks again...
Old 07-24-2010, 11:01 PM
  #17970
w8ye
My Feedback: (16)
w8ye's Avatar
It has happened to me a few times also
Old 07-24-2010, 11:41 PM
  #17971
mistermnkim
My Feedback: (153)
if i blew the oring you were talking about what symptoms would it have? would it affect WOT ?
Old 07-25-2010, 12:04 AM
  #17972
w8ye
My Feedback: (16)
w8ye's Avatar
It would run inconsistant lean and rich, sometimes hard to start. Sometimes quit on you
Old 07-25-2010, 07:00 AM
  #17973
Rudolph Hart
ORIGINAL: mistermnkim
Mark you showoff and ace pilot stop flying it round the field backwards or at least shell out the bucks for a nice pusher prop mate.
Old 07-25-2010, 07:21 AM
  #17974
Cherokee Flyer
See I told you it would happen without any help from me!!
L.
Old 07-25-2010, 07:33 AM
  #17975
beaver180
My Feedback: (10)
Hey OF, ya want some Vegemite or some Pineapple Lumps? My oldies are flyin over tomorrow
