Welcome to Club SAITO !
Old 08-23-2010, 07:23 PM
  #18376
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Default RE: Welcome to Club SAITO !
OS-f never were my favorite, I have two and got tired of trying them in various engines and never seeing any difference. In my opinion the Fox Miracle, Glow Devil 4c special, the Saito SS and the Taipan Silver are all equal to the F in every way. I don't think I'm alone in that.
Old 08-23-2010, 07:33 PM
  #18377
JohnB96041
JohnB96041's Avatar
Am I missing something here? I have several O.S. engines, small and large, and have never had to change the glow plugs. They are all original. All engines run great. This is over the last 15 years of flying. I also have several Saito engines from the 3.00 twin, 3-1.25's, 1.00, .90 twin. All using the glow plugs that came with them. Have not burned one out yet and all engines run great. Have always used PowerMaster fuel, 18% synthetic/caster oil, 15% Nitro. I do sport flying and some 3-D flying. Have two 90" J-3 Cubs, Edge 540, Christen Eagle II, 4 Funtanas, SlowPoke, and P51 Mustang. They are all being flown at this time.
Old 08-23-2010, 08:07 PM
  #18378
w8ye
My Feedback: (16)
w8ye's Avatar
I have not lost a OS plug in years
Old 08-23-2010, 08:14 PM
  #18379
Cherokee Flyer
The only issue I have ever had with an OS plug was the threads on a new one (F), looked like they had been hit with a hammer. Like you they just don't wear out!!
L.
Old 08-23-2010, 08:25 PM
  #18380
FNQFLYER
The numbered Saito plugs were hard to get I usually sourced them out of Hong Kong (Winning, Cindy was nice to me), as I remember No 2's were for my 50 and No 3's were for the 65.  We used the McCoy MC4 a lot.
Re you guys not getting the numbered ones there appears to be a deal of difference with data and supplies such as plugs etc between Australia and the US, interesting.
Old 08-23-2010, 08:45 PM
  #18381
w8ye
My Feedback: (16)
w8ye's Avatar
I don't use anything but the OS "F" as all I have are four strokes. There are some Saito "SS" and Hanger 9 Super Plugs here and there as they came in the engines
The numbered plugs are for two strokes I used to use the #8 unless I needed a hot plug then it would be a A3 or #6
Old 08-23-2010, 09:04 PM
  #18382
Tarasdad
Tarasdad's Avatar
I've always used the Fox Miracle Plug in my Saito. Tried an OS-F and had trouble getting it to idle reliably. Switched back to the Fox and it ran like a Swiss watch.
Old 08-23-2010, 09:05 PM
  #18383
w8ye
My Feedback: (16)
w8ye's Avatar
I cannot get the Fox Miracle to idle worth a toot. It is too cold and the fire will go out.
Old 08-23-2010, 11:30 PM
  #18384
mike109
mike109's Avatar
G'day I have been flying RC models since 1989 and using four strokes since about 1990. I have only once in all that time ever replaced a four stroke plug (apart from a couple that I blew up with 12 volts). My Saito 56 is now about 8 years old and still running a plug I put in when it was about 1 year old (after the 12 volt experiment).
I have had engines from an OS 26 to a Saito 150 and in all cases, I just have used what ever plug came with the engine. Saito in Saito, OS in OS. When I have had to provide a plub I have used OS plugs, usually in ASP and Magnum engines and in my Lasers. I use OS simply because they are all that I can get. At the moment I have a couple of Enya No 3s that I intend to try should a plug need to be replaced.
The only plug I have replaced because it did not work was a Saito plug in a Saito 72. The engine was near new and just would not idle. The plug looked perfectly normal. I put an OS F in it and it was totally happy.
Old 08-24-2010, 12:26 AM
  #18385
FNQFLYER
All interesting comments about the plugs, engines in general use don't have a plug change very often, (like in my car) but as a part of the general tune up each couple of years I generally replace the plugs in my sport engines, the competition ones are a different matter.
For Mike 109 HHQ has them is stock check with your local hobby shop or give Paul Farthing a ring.  Col Taylor is a good source as well in your neck of the woods
Old 08-24-2010, 02:49 AM
  #18386
Ernie Misner
Ernie Misner's Avatar
Thanks LadyFlyer for a clue about the clicking in the valve train. That was driving me crazy because there was not excess play in the clearances. You are the best and a real lady under all circumstances.
Ernie
Old 08-24-2010, 07:19 AM
  #18387
Rudolph Hart
Rudolph Hart's Avatar
ps ernie watch out for those handrolled three paper after dinner cuban seegars too..they improve your hearing
Old 08-24-2010, 09:37 AM
  #18388
blw
blw's Avatar
Mike- that plug in your .72 may have just been a victim of the engine breaking in.
I break in an engine with the plug that came with it. When I'm ready to fly it, I take the plug out and make a note of where it came from. New engines always get a new plug right before they begin flying.
Old 08-24-2010, 10:23 AM
  #18389
w8ye
My Feedback: (16)
w8ye's Avatar
Little metal particles or even non metallic ones that get on a plug's element during operation will lead to its premature demise
Old 08-24-2010, 05:14 PM
  #18390
Charley
Shux ED,
Sometimes ya jist can't help yer nature.... Hang in there....
CR
Old 08-24-2010, 06:28 PM
  #18391
mike109
mike109's Avatar
G'day
I think you are right that the plug suffered during the running in process and died as a result. I have generally been lucky with plugs but this one was a genuine non goer. The engine would just not idle with it.
I had a similar experience with a Super Tigre 51 at about the same time. It too ran in fine but then would not throttle properly. I stuck an OS F in it (the only spare plug I had) and it now runs perfectly. Actually, I should get it out and fly it again in its Stick.
Most of the plugs that I killed were the result of plugging the plug driver into the 12 volt starter socket. Instant death.
Cheers
Old 08-24-2010, 09:10 PM
  #18392
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
How do you get them to do that, the Fox Miracle works perfectly in all my engines that I've tried them in and I've flown more with the Fox than any other. I'm not tyring to be a bad guy but our experience is opposite.
Old 08-24-2010, 09:29 PM
  #18393
w8ye
My Feedback: (16)
w8ye's Avatar
I've run a Miracle in a ASP 65 four stroke and most days the Miracle would run perfect and then first thing you know it just would not idle worth a toot like it was cold. So I changed it out with a OS "F" and left the plug in my flight box.
A few months later a guy needed a plug in his double rocker OS 120 so I gave him the Miracle. He runs Miracles in all his four strokes and that is all he uses almost like you.
Old 08-24-2010, 09:41 PM
  #18394
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
The only engine taht came close to doing as you say was my little .30 on a Fox Miracle and 5% nitro, it was fine on 15%, didn't try 10%. I might be out of 10%. Thanks Jim for the splainin.
Old 08-24-2010, 09:50 PM
  #18395
w8ye
My Feedback: (16)
w8ye's Avatar
To be honest, I should get more and try them in some different engines. That was more than 10 yrs ago.
Old 08-25-2010, 01:30 AM
  #18396
the pope
ORIGINAL: Old Fart
Hey OF did u just say what I thought u said ? If so u can count me in. Cheers from the green pope
Old 08-25-2010, 07:45 AM
  #18397
Rudolph Hart
Yesknow anyone who is tuning a 182 at the moment??
Old 08-25-2010, 08:54 PM
  #18398
JoseN
Ref: How to set the timing of SAITO 72.
Can anybody please tell me in simple worlds (special tricks) or refer me to a ppt or youtube presentation on how to set the timing of SAITO 72. I just change the bearings and found that the operating manual includes very limited information on how to do it. Also, which one is the most appropriate size of propeller to run it in a Goldberg Tiger 2. I am using 12x8.
Thank you in advance for your kind reply.
Old 08-25-2010, 09:05 PM
  #18399
w8ye
My Feedback: (16)
w8ye's Avatar
For the Saitio 72 a 12 X 8 is OK
Set the timing by having the crankshaft pin at top dead center
The cam has a dot on the gear. This dot goes straight down
There is a hole in the intake cam lobe. A pushrod will engage this hole when stuck through the intake cam follower hole to hold the cam steady with the dot straight down
The valve lash is set .002" to .004"
Old 08-25-2010, 11:29 PM
  #18400
JoseN
It worked according to your instructions.
Thank you very much for your help.
