Welcome to Club SAITO !
Old 09-21-2011, 02:17 PM
  #20901
hsukaria
Default RE: Welcome to Club SAITO !
Manifold injection was also called Throttle Body Injection (TBI). It was an improvement over a carburator because of improved fuel control and does not use a venturi. A venturi causes a vacuum in the intake manifold for fuel suction, but also causes power loss because it lowers the cylinder pressure.
Port Fuel Injection injects fuel just upstream of the intake valves. It is an improvement in performance and emissions over throttle body injection. But still suffers from fuel puddles accumulating on the back of the intake valve.
Direct fuel injection started out in diesels, but is now also used in the latest gasoline engines. It provides the best fuel control, and power. The biggest benefit of gasoline direct injection is that when the fuel is injected at the compression stroke, it actaully causes a rapid cool down of the compressed air, allowing for reduced pumping losses by allowing the air to cool down and condense right before combustion.
As mentioned before, the fuel injection in model engines would be the throttle body (or manifold) injection. If done properly, besides helping with fuel control, it can help with increasing power by eliminating the carb venturi.
Old 09-21-2011, 02:45 PM
  #20902
earlwb
earlwb's Avatar
ORIGINAL: hsukaria
Actually they did that with the glow engines already. The combat, speed and hi-perf FF engines used bladders that you inflate with fuel. The bladders developed a lot of pressure too. The intakes on the engines then used a large intake hole with no venturi, since they don't draw fuel the intake can be made larger, and the needle valve assembly usually wound up being a 1/2 length/size unit on one side and it sprayed the fuel directly into the intake with no obstructions inside.
The pylon racers did it to some extent as well (at least until idle rules in some classes were implemented).
OS went all the way and marketed a real fuel injected 4 stroke engine for a while, with a real fuel pump, fuel injector and a ECU unit.
Old 09-21-2011, 04:46 PM
  #20903
hsukaria
ORIGINAL: earlwb
ORIGINAL: hsukaria
I've been told about the OS fuel injection before. I bet it wasn't cheap, but OS is never cheap.
Old 09-21-2011, 04:57 PM
  #20904
flyingagin
flyingagin's Avatar
ORIGINAL: hsukaria
ORIGINAL: earlwb
ORIGINAL: hsukaria
I have have looked but have not seen or heard anymore than what I have seen here. Not interested in owning one just curious. I like motors. Any I only have a rubber band motor budget
pics? links? data?
Old 09-21-2011, 05:10 PM
  #20905
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Test post
ID:	1665184   Click image for larger version
Old 09-22-2011, 03:02 AM
  #20906
Rudolph Hart
Rudolph Hart's Avatar
I'm sure happy i read all these posts it's a lively conversation.I'm going to start off running a vp20 pump and exhaust pressure.
Old 09-22-2011, 03:24 AM
  #20907
earlwb
earlwb's Avatar
ORIGINAL: flyingagin
pics? links? data?
It is pretty awesome in that the ECU controls the engine, so there are no needle valves to adjust. If it wasn't for the cost, it might have revolutionized the glow engine market especially with beginners.
OS advertisement for them http://www.os-engines.co.jp/english/...0sfi/index.htm
OS had a .91, 1.60 and a 2.00 fuel injected engine.
Tower Hobbies still has some parts even.
http://www3.towerhobbies.com/cgi-bin...=OSMG0941&P=OW
OS had a 2 stroke 1.60 with FI:
OS FS091FI in use. it is not mine though. Sorry.
Old 09-22-2011, 04:34 AM
  #20908
w8ye
My Feedback: (16)
w8ye's Avatar
Life wasn't so simple as fly out of the box with the OS FI engines as you had to follow a procedure to establish the limits of the fuel mixture algorithm about as often as you would need to adjust the needle valve on a regular carb engine. You would get along with the same limits all summer but in the fall as the weather started getting a little cooler, you would have to set the limits up again.
Old 09-22-2011, 04:46 AM
  #20909
flyingagin
flyingagin's Avatar
WOW those are some awesome engines> Beautiful
OH well rubber band motors for me.
I will stay with my Saito .65 and ST, and OS that I have.
Old 09-22-2011, 06:59 AM
  #20910
Kostas1
Kostas1's Avatar
ORIGINAL: w8ye
But it was a really nice and innovative idea anyway, right;
Old 09-22-2011, 07:02 AM
  #20911
hsukaria
Those fuel injected engines are awesome. But I'm sure only the professional competition guys would spend that kind of money (or you are crazy about engines).
I'm just happy I was able to replace a piston ring on one of my cheaper 2-strokes last weekend. I will bench run it soon to break it in. Simple pleasures.
Old 09-22-2011, 08:01 AM
  #20912
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
As you can see my pictures posted some time after I actually posted them. The YS 1.15 finally has the regulator where it should have been all along. The 1.70 has the fuel injection pump on the intake pushrod and the mixture is controlled by the carb barrel
Old 09-22-2011, 08:20 AM
  #20913
hsukaria
ORIGINAL: Hobbsy
The picture on the right has a servo pigtail wire. Does that connect to a receiver and eliminates the throttle servo? The FI also controls the throttle?
Old 09-22-2011, 08:26 AM
  #20914
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I suspect that would be a throttle position sensor to make the fuel injection more accurate, that's just a guess though.
Old 09-22-2011, 08:31 AM
  #20915
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
PS. I just did some more digging and that engine is a new 1.75 that is, "comming soon" there is no explanation for the wire.
Old 09-22-2011, 09:11 AM
  #20916
gkamysz
My Feedback: (19)
gkamysz's Avatar
The wire in the YS DZ-1.70 CDI photo is for the spark trigger. I just got a FS-91S-FI. I'm looking forward to trying it.
Old 09-22-2011, 10:19 AM
  #20917
hsukaria
ORIGINAL: Hobbsy
Oh, so those pictures are not off your workbench? I was marveling at how clean your workbench is compared to mine.
Old 09-22-2011, 10:24 AM
  #20918
hsukaria
ORIGINAL: gkamysz
FI for a spark engine would be great because you already have to have the electronic ignition module and battery anyway. So you add an extra couple of wires for the injection system and you're all set. That might be feasible from a cost/complexity point of view. Plus the FI would incorporate the function of fuel pumping and pressure regulation!!!
Old 09-22-2011, 10:50 AM
  #20919
Nikolas K
OS electronic fuel injection is a nice concept, but judging from the instructions manual, the tuning of the injection system is something complicated and aimed for experienced modellers. However, I believe that if the simple glow carb was inadequate, electronic fuel injection would have taken its place (just like in automobile engines). Talking about fuel injection however, what makes 4 stroke YS engines system a "fuel injection" system?
Old 09-24-2011, 11:30 AM
  #20920
JariV
My member number can be released for someone else. I sold my only Saito engine.
Old 09-24-2011, 11:44 AM
  #20921
hsukaria
ORIGINAL: JariV
Don't you know that the Saito Club is like the mafia, once you join, you can never quit.
Old 09-24-2011, 01:08 PM
  #20922
triumphman49
My Feedback: (149)
Hi JariV, What other types of engines do you have?
T-man49
Club Saito #723
Old 09-24-2011, 01:28 PM
  #20923
NM2K
My Feedback: (14)
He'll be back. Saito engines are habit forming. (smile)
Ed Cregger
Old 09-24-2011, 01:31 PM
  #20924
hsukaria
ORIGINAL: NM2K
Ed Cregger
I ran my Saito 1.8 earlier today. I'm still in Cloud 9.[8D]
Old 09-24-2011, 02:09 PM
  #20925
KenD
My Feedback: (65)
What is the requirements to become a Club Saito member?
