Welcome to Club SAITO !
Old 08-04-2012, 06:45 PM
  #22851
lopflyers
My Feedback: (12)
lopflyers's Avatar
Default RE: Welcome to Club SAITO !
(I now have more $ in this used engine than a new one costs!) But reworking it was fun.
In any other endevour that would be crazy. Only on RC airplanes this sentence makes sence.
Old 08-04-2012, 07:02 PM
  #22852
blw
blw's Avatar
Treehanger- you are the official man of the hour. Great pics of the cam. If I had done the same thing I wouldn't consider any money wasted. You did the right things and will probably have the engine back to being the sweethearts they are.
Old 08-04-2012, 07:07 PM
  #22853
blw
blw's Avatar
We had a couple of those 250cc gas burning 4 stroke radials. They were for a FW. I once held the elevators behind my ankles as they ran up the engine INSIDE the hobby shop one night. Big mistake. I was in serious pain after a long wide open throttle run. They sound incredibly good. They. Smoke up a hobbyshop good too.
Old 08-04-2012, 07:24 PM
  #22854
SrTelemaster150
SrTelemaster150's Avatar
Gotta love that castor oil!
ID:	1789179   Click image for larger version
Old 08-05-2012, 12:19 AM
  #22855
Rudolph Hart
Rudolph Hart's Avatar
I DO... dribble a bit on the hot plate for the neighbours bbq,the sausages taste awesome
Old 08-05-2012, 03:24 AM
  #22856
Cougar429
Cougar429's Avatar
Ah, castor oil. For that "Get Up and Go" feeling.
Treehanger, that build up is considerable and the worst I've seen in a long time. You must have been putting out enough smoke to hide the Normandy landings! All that does lead towards the suspicion either a sticking valve or some of that getting between the valve face and seat. Drop it in a crock pot of glycol and it would come clean in a few hours.
As for starting, I find mine sans choke need a slightly open throttle to start, (still below 1/4). Once fired off and warmed for a few seconds it can be brought back down.
Old 08-05-2012, 06:04 AM
  #22857
treehanger
This was the way I got it used. I had neverdid runit before these pictures. Yes, I did crockpot it! Still took a lot of work to remove what was left.
Yesterday I used 17% oil w/ caster/syn mix. 10% nitro to test it out. Maybe I should use 15%.
Bob
Old 08-05-2012, 06:13 AM
  #22858
rcflyboy01
I have been running 20% caster and 80% synthetic oil in my Saitos engines. I have a buildup of carbon in my muffles and manifolds. The carbon is causing my engines to run hot and leans out on me. Outside of buying a new muffle, I need some ideas on how to clean out the back carbon?
Old 08-05-2012, 07:07 AM
  #22859
SrTelemaster150
ORIGINAL: rcflyboy01
ORIGINAL: treehanger
This was the way I got it used. I had never did run it before these pictures. Yes, I did crockpot it! Still took a lot of work to remove what was left.
Bob
15% Cool Power is all I use. No castor, 100% synthetic.
Old 08-05-2012, 10:34 AM
  #22860
Cougar429
Cougar429's Avatar
rcflyboy, the crock pot and glycol will do an amazing job if left long enough.
Old 08-05-2012, 10:39 AM
  #22861
SrTelemaster150
ORIGINAL: Cougar429
So will an overnight soak in Dawn Power Dissolver followed by a hot water rinse then a soak in vinegar to nuetralize it..
Old 08-05-2012, 10:40 AM
  #22862
SrTelemaster150
Delete double post.
Old 08-05-2012, 10:42 AM
  #22863
JariV
SrTelemaster, regarding the Moki conrod offset; the two opposite slave rod big end pin locations are closer to each other than the other pins on the same base circle. So all pistons have the same stroke, only two of the pistons move in slightly different "rhytm" than the other three.
Old 08-05-2012, 12:47 PM
  #22864
blw
blw's Avatar
ORIGINAL: SrTelemaster150
ORIGINAL: Cougar429
So willan overnight soak in Dawn Power Dissolver followed by a hot water rinse then a soak in vinegar to nuetralize it..
That is too long for some aluminum. You have to spot test it past 15 minutes. I've gone 45 minutes on Saitos and Evolutions. Dawn Power Dissolver is wonder stuff, but it can darken aluminum if you aren't careful. I rinse it off by spraying alcohol liberally all over the surfaces. Sounds like you are confusing that with the antifreeze cleaning method.
Glycol = antifreeze
Old 08-05-2012, 01:01 PM
  #22865
blw
blw's Avatar
Got some new members.....
The Raven #788
jkr_1100 #789
treehanger #790
Tom Englehart #791
It's great to have you guys in the Club. Anyone else?
edited to correct boneheaded counting. Treehanger and Tom both had number changes. Sorry about that and thanks to Tom for pointing it out.
Old 08-05-2012, 01:11 PM
  #22866
jimbrock
My Saito FA 91s quit running for no reason at all. Replaced the glow plug, put in new fuel. Hmm. Will try again when it quits raining
Old 08-05-2012, 01:16 PM
  #22867
jimbrock
Ozburn? Did I hear Ozburn? Jim B, ChE API 1952. Learned to fly Aeroncas at the Auburn-Opelika airport.
"Fairest village of the plains."
Old 08-05-2012, 01:38 PM
  #22868
rcflyboy01
The black carbon build up is inside the muffler. Will the Dawn Power Dissolver dissolve the carbon. Also the carbon is on the exhaust valve, top of piston and head.
Old 08-05-2012, 01:50 PM
  #22869
orthobird
and you have rain? i wish we did, it is scorching hot here, cannot go outside to fly, temp = 102
Old 08-05-2012, 01:51 PM
  #22870
orthobird
how about me? i have 3 saitos:fg 36,gk100,125
ORIGINAL: blw
The Raven #788
jkr_1100 #789
treehanger #791
Tom Englehart #792
Old 08-05-2012, 01:56 PM
  #22871
JohnB96041
JohnB96041's Avatar
ORIGINAL: orthobird
102? I guess it is time for the winter coat. How about 113.
Old 08-05-2012, 02:23 PM
  #22872
jkr_1100
My Feedback: (15)
jkr_1100's Avatar
BLW, thank you, I have been reading for several weeks, I started on page 1 and wondered if numbers were still given out. i just picked up a funtana 40 with an OS 70. now I will have an OS to compare to my Saitos. By the way i was visiting a buddy that had an RC boat kit with a Saito 4 cylinder steam engine. He said he got the boat but not the engine. I really wanted to see that one.
Cheers,
Old 08-05-2012, 02:51 PM
  #22873
SrTelemaster150
ORIGINAL: JariV
SrTelemaster, regarding the Moki conrod offset; the two opposite slave rod big end pin locations are closer to each other than the other pins on the same base circle. So all pistons have the same stroke, only two of the pistons move in slightly different ''rhytm'' than the other three.
OK, I see. 3 cyliders (the master & 2 adjacent slave rods 5-1-2)are equally spaced as far as degrees while the remaining 2 (3-4)are spaced a few degree closer W/the widest gaps between 2-3 & 4-5.
That's how they are getting the Harley "V" twin "lope" effect. Several different degree patterns per cycle.
Me likey!
Old 08-05-2012, 02:55 PM
  #22874
SrTelemaster150
ORIGINAL: blw
ORIGINAL: Cougar429
Not confussing them but you are right, probably more like 4 hours W/the DPD sprayed liberally on the parts laying on a cookie sheet.
The vinegar is a good trick though. The weak acidity brightens up the aluminum & neutralizes the akalinity of the DPD.
Old 08-05-2012, 03:07 PM
  #22875
SrTelemaster150
Yes, spray on a thick coating, let is soak on a cookie sheet for a few hours & go after it W/a tooth brush/"Q" tip/rag.
Rinse it thoroughly in hot water & repaet if needed. When it is clean, emerse in a bowl of strong vinegar/water solution, (about 1:1) & let it soak for a few more hours, then rinse in cold water. Blow it out W/compressed air.
If the aluminum darkens, just give it a light coat of flat silver Rustoleum (1200*) BBQ paint. Let it dry & then bake it in the oven @ 300*F for about an hour. Do not handle the part directly W/oven mitts until it cools. The paint will still be a bit soft when hot, but it will harden & be completely fuel proof once it cools.
