Kit sacrelige.. Bad Baby Birdie mutant
..but don't worry I am drawing up the model as I go. And I plan to pull a mold or at leasy a plug from the canopy. So the 1/2A version can be repro'ed.
I had it set up in the front end for a CX-11, but I'm putting that in the Goldberg Chipmunk instead. And I needed a quick & fun test bed to fly the MDS .15. So I'll fully sheet the wing, firm up as necessary here and there, shorten the aileron and use dual servos, battery and servos in rear of fuselage.
Shortened the nose 1" too, that will help the CG. Bet it still comes in at a decent weight, kit spec is 22oz. Engine and pipe is 7.3 oz.
What is the pipe length from the start of the stinger to the center of the piston?
Big fat convergent / divergent volume should be less peaky on the NV. What
prop and rpm are you expecting.
It's the same pipe that ran 30.5k on the bench prop. The stock MDS pipe was 2.5-3k below that. This is a used Profi F2A pipe, I froze water in the header section and tweaked it to clear the fuse. There is also a repair over the weld. I'll cowl it to hide the ugliness.
Props in 5.5" diameter range, 5"-6" pitch. Likely a clipped Graupner 6x5.5 to start.
The bend worked fine, I'll bench run it soon as it's hospitable enough. However - tech tip: don't fill the pipe all the way. I got this technique from brass instrument making techniques, but those are either constant diameter or tapered bore tubes. In the case of the pipe, with the fat center section and tiny stinger outlet.. hmm, tough to expand. I split the weld, soon as I took it out of the freezer I thought "dumbass, why didn't I just fill the header..?".
The ugly bits are my JB Weld/glass repair. The pipe still weighs 29 grams which is the same as the new Profi pipe, so I'll live with it. It's a test bed..
p.s. Missed your question, I'll measure up the pipe and let you know.
The airfoil looks funky in the pic, but the paper is a bit mangled in that area. The airfoil thickness is definitely not conducive to top speed, but I figure there is enough power on tap to move briskly enough. Don't want to make a total project out of it, simple conversion and some giggles is the goal.
No it is stock from the firewall back - just an optical illusion. What may be fooling you is the 1 inch I lopped off the nose last night, the parallax error holding my iPhone up in the air, and the plans are all ripply from abusive fondling and poor rolling over the years.
I know the airfoil is fat, but I don't want to get mired down in modifications. I've seen an ACE wing do 120mph on 300 watts, which I think is roundabout the power of a reasonable sport .15. So this should do at least that..
200 squares, even at 24-25 ounces, will be a reasonable wing loading. Safe enough to land more than once anyways. In theory.
UPDATE: no it's not a NACA 2416, might be a Staedtler-Mars special based on one, dunno. I smoothed out the plans and looked more closely at the ribs - the lower surface has been flattened from the rear of the spar to the TE. Definitely more camber than it needs in this incarnation.
I can't see any use for a working rudder on this, but I might need the servo weight in the rear. The Simple 400 used to do fun things when I pulled the sticks to the bottom corners at full speed.
It seems a bit drastic to go from a .049 engine to a .15 engine with a tuned pipe...
Wasn't there a Birdie 10 as well, it might be better suited?
The few planes with a thick wing profiles that I have put more power into, didn't really shine. Perhaps it's just me but a low weight and modest power, seems to make for a better overall performance.
I agree, but I am not going for an optimum solution, nor do I expect this thing to have good manners. This is a quick and dirty conversion only. I am not sure the .10 size would perform on the tiny props needed for this engine. It could be a snarling screaming disaster waiting to happen. Sounds like fun to me.
- Propeller. The best speed was achieved with a Master Airscrew 7x5 S-2 G/F Nylon Gray Propeller cut to 140 mm (5.5 inches) diameter. With this prop the engine was turning about 30,000 rpm in the air. I suggest starting with 6 inch diameter and cutting the prop until the engine pipes up. Too small propeller will turn a lot of rpm with no thrust. We also tried more pitch (up to 6.5 inches) but this did not result in faster speed.
- With these modifications and settings the system performed quite well. The fastest time achieved in a practice session was just over 200 kph, which is excellent considering the exposed lines, landing gear and no engine cowling. The airplane routinely did around 160-180 kph with a Rossi pipe and slowed down to 150 kph on the stock pipe (on FAI 80/20 fuel).
Even though this is just a sport 1/2A model by design, with no lines there is every possibility it will leave the ukie trainer in the dust. As mentioned ad nauseum, I clocked 126 mph on a Simple 400 - similar wing - with about 300W electric.
I suited up against some cool winds today, had to bench run the MDS .15 with the mangled bent pipe. Responding to taunts from fellow RCU members to run it with a flight prop, I made a 5.5x5 from an APC 7x5. It staged without much trouble (hmm, more prop load) and recorded 27,800 without trying to squeeze it to death.
Made a new stab today, also fixtured the fuselage between two Al extrusions and tacked the tail together nice and straight. I am moving the vertical stab back stab stays in stock position, but internal linkage. 1/64 ply caps cover the joiner pockets in the middle photo.
I was debating between stiff 1/8" or 3/16" for the tail group. I went 1/8".. once it is anchored to the fuse it should reveal if more torsional stiffness is needed.
So far I have only used the kits fuselage, we'll see what is left. My intent is to build the kit wing and sheet it. I will try to avoid the urge to redesign the wing and start from scratch with a 10-12% airfoil.. no-o-o-o just get it done and move on..
I am not sure of the spread on the pipe response. It staged on the ground run yesterday without distress, needled easily, and ran cool enough. But it recorded 30.5k on the pitchless bench prop and 27,800 on this. So.. I am thinking launched rich it should unload and sing away a couple of k rpm higher. May take a bit more shaft load based on the easy staging.
Weighs in at 11.0 oz as you see it. With care I wonder where it could end up:
Blind guess time:
Wing 5oz
Battery .8oz
Servos: 1.4oz
Rx: 0.2oz
finish the cowl area, glass/prime/finish and film: 3 oz?
Tank: 1.5oz
Linkages and other crap: 1.5oz..????????
13.4oz + 11.0oz = 24.4oz.
So if I'm real lucky should end up around 16oz/sqft wing loading, more likely 17-18oz/sqft. Won't be a floater but should return to earth safely enough.
Don't need a rudder and esp. don't want to deal with two concealed linkages. Don't need a sub-fin either. The wing is so simple, I may just take the extra couple of hours and cut replacement ribs and leave the kit wing alone. That way I just have to replicate the fuselage (it's really simple) and voila have all the bits again. I'll get it all CAD drawn first, then build a new fuse and old flying surfaces and make a 1/2A version. I already made the plug for a glass/epoxy canopy mold.
Blind guess time:
Wing 5oz
Battery .8oz
Servos: 1.4oz
Rx: 0.2oz
Tank: 1.5oz
