Ac 36 sprint cat
Ac 36 sprint cat
Old 07-25-2016, 04:52 PM
gzee
Default Ac 36 sprint cat
Looking for advice on the best size zen for this boat looking for high 50's bought it used with a qdraw that needs to be replaced. Using it for sport And have a couple a 2716 for props
Old 07-25-2016, 06:34 PM
mistycreekboats
mistycreekboats's Avatar
If it's a 36" Sprint Cat it's a Aeromarine not AC - AC makes a 36" Nitro Cat but no easy task to fit a Zen in it
Post a pic of your boat - most likely a Aeromarine - easier to help when we see what you have
Old 07-25-2016, 06:40 PM
Ron Olson
Ron Olson's Avatar
Send the QD in for a rebuild or update. They'd rather do it right for you than for you to try it. A freshly rebuilt QD should take a lot more prop than that.
Old 07-26-2016, 08:27 AM
gzee
Sorry it is an aero sprint cat will try to send pics is there anyplace in Canada that can rebuild a QD thought a stock 360 pun would be more reliable and easier for a new be to run
Old 07-26-2016, 09:04 AM
mistycreekboats
QD is in US but they do rebuilds for Canucks all the time give them a call
http://quickdrawengines.com/
Most of the time a rebuild is cheaper than a new Zen - and will out perform a stock Zenoah pretty easy
Call em see what they say
Randy
Old 07-26-2016, 12:10 PM
Ron Olson
Ron Olson's Avatar
It's a good reliable motor. For the money you'd drop for a new Zenoah you're better off getting that one rebuilt by QD. Those engines are monsters no matter how old or new they are. They're anal about doing things right.
Old 07-26-2016, 02:21 PM
gzee
Thanks i will get in touch with them to see how much they want to get it right the shipping is what might kill me. still going to try to send some pics have not done that before
thanks
Old 07-26-2016, 03:43 PM
mistycreekboats
thanks
The shipping is not that bad. But a QD redone by QD is well worth the money and has waaaaay higher resale valve than most Zens
QD always does FIRST CLASS work and will not rip you off and will do what is needed for power and reliability
Randy
Old 07-26-2016, 04:14 PM
mistycreekboats
To Post pics
ID:	2174533   Click image for larger version
ID:	2174534   Click image for larger version
ID:	2174535   Click image for larger version
Old 07-26-2016, 04:23 PM
gzee
here are some pics
ID:	2174539   Click image for larger version
Old 07-26-2016, 04:24 PM
gzee
thanks for your help on pics
Old 07-26-2016, 04:54 PM
Ron Olson
Ron Olson's Avatar
You can also use the "Go Advanced" at the bottom right side of the reply box.
Go down and click on the "Manage Attachments" then use the uploader to take shots from your computer so at that step it's identical to the way that Randy told you.
mistycreekboats
That's a darn good set up - worth getting rebuilt for sure - and keep that pipe (exhaust) that's a factory QD exhaust very good power when running good
Old 07-26-2016, 05:02 PM
Ron Olson
Ron Olson's Avatar
He's right you know. That hot pipe setup alone is a good $200.00 by itself. It's a newer engine and is well worth saving. I had one in a 'rigger and regret selling it with the boat when I sold it.
Name:	http___www.kodakgallery.com_imaging-site_services_doc_5505_817800130508_jpeg_BG.jpg
Old 07-26-2016, 06:57 PM
gzee
bought the boat used had the walbro257 rebuilt. have the carb set close to what is recommended. using 2716 props, runs great in the driveway but having a hard time getting it to run under load you get a lag and it stalls How do you guys make adjustments for this without it being stuck out in the pond.Have been trying for 2 summers and had it running for a while but no where near as good as it should be. so i thought a new motor might have been the answer. I have run E/L boats for a bout 5 yrears and this is the first gas. If you can offer any advice it would be a great help
Old 07-26-2016, 07:33 PM
mistycreekboats
Make sure all the gaskets on intake are good - what are your settings ? 257 usually 2 low 1 high
What runs good on land doesn't mean it will run good under load
Fuel system good ? Spark plug good? a new carb is 30 bucks us and worth trying before a fuel $$ on rebuild
Old 07-26-2016, 07:40 PM
mistycreekboats
That looks like a 644 cover plate on it if that's a 257 ? 257 has a flat plate on top
http://www.gizmomotors.com/index.php.../wt-257-detail
Maybe carb is mixed and matched but doesn't look like normal 257
Old 07-26-2016, 07:44 PM
mistycreekboats
I sent you a pm
Old 07-27-2016, 03:17 PM
gzee
i sent you a pm
Old 07-27-2016, 07:08 PM
Ron Olson
Ron Olson's Avatar
Good eye Randy! Walbro's primered carb doesn't have the smooth bore like that one does. The previous owner may have put it on himself. Most people don't use those carb's although they are good as most find that all you have to do is place a finger or thumb over the opening to draw fuel in the pull it over slowly until your digit is wet.
Old 08-02-2016, 03:09 PM
gzee
i am putting in a new coil up front and i have a new 257 to install after that
Old 12-05-2016, 05:41 PM
gzee
thanks to all your help i had a much better summer at the pond the boat ran well , still adjusting but running high 60's getting mid 70's new 257 carb,coil was moved to one of the stringers ,strut angle was adjusted ,gap on plug changed thanks again guys for talking me out of a new motor
Old 12-10-2016, 03:11 PM
mistycreekboats
Glad you got it to run better
