Kingtech Gen 3 Question
Old 10-27-2016, 09:34 AM
ozief16
My Feedback: (13)
Default Kingtech Gen 3 Question
Gents,
One test ive always run on a new plane is to take fuel pump output and run it back into my fuel jug and then run the pump at max voltage until the tanks are empty a few times. It helps me to identify fuel system issues without wrestling g with a motor at full power.
I just switched to KT and can't figure out how to do that in their menu. I can activate the pump at low voltage but can't figure out how to up it. A little help please?
thanks
Dave
Old 10-27-2016, 10:24 AM
gunradd
My Feedback: (9)
gunradd's Avatar
Originally Posted by ozief16
Gents,
thanks
Dave
Hello Dave
I do the same on all my installs and this is a very good practice. If this is the Xicoy ECU I can help you. If its the new ECU I have no clue and you should give Barry a call. You said gen3 so I assume this is the new ECU. Some Gen 3 K210s still have the xicoy ECU so that's why I ask.
Old 10-27-2016, 10:52 AM
ozief16
My Feedback: (13)
It's the new ECU which appears to be awesome.
Thanks for trying!
Dave
Old 10-27-2016, 12:53 PM
Scott Todd
My K-45 showed up! Great shipping. Ordered on Tuesday, arrived today. I should have it flying next week. Look on the Turbinator 44 build thread for updates.
The anodized aluminum ECU and GSU are really nice. It shipped with the battery and FOD screen I ordered in the box. Nice!
I look forward to the answer on running the pump. If you call him, please ask Barry to answer here too.
Another Question: The FOD screen just barely fits onto the end of the starter motor housing. Is it OK to use longer cover screws and washers to hold it in place?
Scott
Old 10-27-2016, 02:49 PM
RCRice
RCRice's Avatar
On the new Kingtech ECU/GSU the first screen is called the Dash Board. Touch anywhere on the Dash Board to get the Home Screen. On the Home Screen touch the Test Icon.
Press <4> next until you get (at the top) page 6 of 9, TestPump. Press <1> multiple times to increase pump speed. Press <2> to stop. Press X top right to return to Home Screen.
Old 10-27-2016, 04:59 PM
dccatl
Originally Posted by gunradd
Hello Dave
Could you please explain how to do this with the xicoy ecu. Is running the test/prime pump from the test menu all that's required to run it at max voltage?
David
Old 10-27-2016, 09:24 PM
RCRice
RCRice's Avatar
Yes that should do it. You can also run the pump by plugging it directly into the ecu battery. I've sometimes needed to do this to get a "stuck" pump running again. I would not do this for a prolonged run.
Old 10-27-2016, 11:33 PM
dubd
dubd's Avatar
How are these G3 engines different from the G2s listed on the Kingtech USA web site?
Old 10-27-2016, 11:57 PM
RCRice
RCRice's Avatar
I'm not aware of a G3 engine. A little confusion on the terminology. Series 2 turbines have new pumps, KingTech ECUs and GSUs. K-140G2 and K-160G2 are redesigned turbines that have the new smaller footprint than the original K-140 and K-160.
Old 10-28-2016, 12:58 AM
gunradd
My Feedback: (9)
gunradd's Avatar
The G3 is only the later SN K210s. It is not a different series of engines.
Old 10-28-2016, 07:26 AM
causeitflies
causeitflies's Avatar
Ok, so what's the difference in the later 210s and at what serial # does it start?
Old 10-28-2016, 04:22 PM
gunradd
My Feedback: (9)
gunradd's Avatar
Not sure what the difference is. All the engines evolve and get upgraded over time. The good part is when you send an engine in for service it gets the upgrades.
Old 10-28-2016, 06:51 PM
causeitflies
Thanks Chris. Does the upgrade include the new ECU or just engine parts?
Old 10-29-2016, 06:31 AM
ozief16
My Feedback: (13)
Guys,
ive tried bumping #1 multiple times while the pump is running in the test pump mode to no avail. If I do the prime function and bump it multiple times it works as stated above.
Dantley, my understanding of the G3 differences, which is very limited, is the auto relight feature. I was test running the engine yesterday and powered up to taxi (after I had been taxiing a while) and it started hesitating badly. Imagine my surprise when I walked up to it and realized it was running out of fuel and continually relighting!
I have this engine in a a PNP F-16. It fits fine and looks great. I used one of the two smoke tanks for fuel and left the other one smoke. I will let you know what I find for flight times, but I'm anticipating 7 min at reasonable throttle settings
Dave
Old 10-29-2016, 06:52 AM
dubd
dubd's Avatar
Dave, are you using 210 in the F16 pnp? I have a Tbirds F16 pnp on the way and I'm debating on whether to use a 210 or 160.
Old 10-29-2016, 01:21 PM
gunradd
My Feedback: (9)
gunradd's Avatar
160 bro with out ordnance. It would be easy to over speed it without the drag with a K210. You can even overspeed it with all the ordnance on it with a K210. ITs a super light plane and does not need much push.
