What should i get?
What should i get?
I recently won some money in bets, and im looking to get a nice tank 1/16. What would you suggest? What is your favorite? What is the best?
Depends on how much you won.
Price permitting, Tamiya 1/16 tanks are an excellent choice. I have the M26 Pershing and would also like to get the KV-1.
Taigen are a bit cheaper and also very good. I like the metal upgraded Panther.
There is plenty to choose from. Pick what you like and then ask for feedback on a particular tank.
Cheers
Afrikakorps
Cheers
Afrikakorps
Do you want a really good tank? Do you want to build or ready to run? Do you want it to shoot airsoft bbs or be an infrared battle tank like laser tag.
Are you capable of fabricating, custom model building and doing mechanical work?
These questions will help determine what direction you should go.
Cheers
Afrikakorps
Cheers
Afrikakorps
I do love a m4a3e8 with the 76mm turret or a traditional m4a2 sherman. I also would do a panther.
I would love to build mine. I think that would be a good idea considering i eventually want to so custom tanks, so it would give me a good feel for the contruction and workings of them.
I would love an infared tank, one i can build from a kit. I had in the past wanted, for my first 1/16, to build my own custom m1917 tank and i have the blueprints all made for it, but im concerned that building a custom tank off the bat would be a little advanced.
If you want to build an IR Panther, look at the tamiya Panther kit. You'll also need a 4 ch transmitter and receiver as well as a battery and charger. For IR battling you'll need to pick up the battle unit which is plug and play but does not come with the kit. You can grab the kit and radio from the AAF tank museum. Can't seem to find a battle unit on their site, but here's one on ebay.
http://shop.aaftankmuseum.com/Produc...ductCode=56022
http://shop.aaftankmuseum.com/Produc...tCode=FUTK4200
http://www.ebay.com/itm/TAMIYA-Hopup...AAAOSwu-BWP~SO
Ok you seem competant for my suggestions.
im a shermaholic. Done or planning it all.
unless you use a tamiya electronic system either in a tamiya tank or a custom tank with tamiya electronics, you will need to purchase an after market control system like and ibu2 or a clark 22 board so that the tank can run the same IR code to play the standard tamiya IR battle. Henglong and taigen have IR but it does not work with tamiya.
two ways to build an ez8.
Buy a tamiya sherman and a urethane kit from nick aguilar that includes the rear deck conversion to an m4a3 v8 deck, a t23 turret with 76mm gun and new transmission cover. This takes some fitting to do but it makes a wonderful model when you are finished. I love mine very much and had some trial and error building it. I kept it 100% tamiya so i used a tiger recoil and pershing electronics because they have the v8 sound and recoil control, the stock tamiya sherman electronics have the radial engine sound and no recoil output.
the other option is to throw a clark tk22 or ibu2 board in it. I prefer the ibu2 very easy to set up with a pc and it drives a servo recoil or tamiya recoil.
another easier way to build an ez8 is to buy the taigen 76mm m4a3 or their kit(without electronics and gear boxes) and buy a tamiya sherman kit. Install the taigen hull unto the sherman chassis and make new fenders front and sides onto the taigen hull and wala you have an ez8 ez peazy. Add your own electronics weather it be the stock sherman tamiya system (no reocil and wrong engine sound) or persing electronics, or aftermarket clark or ibu2.
i have a build thread on the forum for my tamiya ez8 and several ongoing sherman threads involving custom models with ibu2 boards and servo recoil.
what ever you pick to build, we are here to help!
Start with the Tamiya Panther. You won't be sorry, you'll have a great tank when you're done and the build will give you plenty of experience for building other tanks later.
What do you think of the taigen tanks? Are they of the same quality of tamiya?
ID
You want to build a WWII tank kit that is metal and can be IR? Taigen kits are probably a good place to look.
http://www.taigentanks.com/taigenkits/
The taigen sherman is more robust than the tamiya sherman.
The taigen is not as finely detailed as the tamiya body but its pretty good.
i really do like the taigen shermans, i have a few that have been all taken apart to build other shermans that are not offered like small hatch (75) early models.
Well, I thought i would just through my 2 cents into the ring again( Aussie expression) and say that all the replies are very good.
Though I would have to agree with Crius, with a Tamiya Panther you will gain good building experience for RichJohnsons M4a3e8, an excellent build.
Good luck either way, and as Rich said "what ever you pick to build, we are here to help! "
Cheers
AK
Cheers
AK
On my way building a second Tamiya Panther lower hull... actually a Jagdpanther so that build is challenging and enjoyable enough and has many options to create several versions of either tank.
SO if you have the available capital, like to build, want a Tamiya IR ready/capable system and want to be in control right at the beginning as to what version you want, either kit is for you!
Jeff
