KingTech TP60 mount
My Feedback: (7)
What are you mounting it in ? Generally the airplane manufacturer offers a mount for turbo prop planes. For example I believe CARF offers a mount and exhaust pipes for their Tucano.
If it's a scratch build or a modification you'll probably need to design your own. I converted a Phoenix Tucano from 60cc gas to K45 TP and I needed to design my own mount.
My Feedback: (53)
But, I would run and extension from the firewall to support both the front mount and the side mount…..maybe a metal piece….
My Feedback: (7)
As I mentioned, I made a mount for the K45TP I installed in my 60cc Phoenix Tucano. It had a firewall for a gas engine similar to what you describe except there wasn't enough room between the firewall and the front of the cowl to fit the K45TP. I removed the firewall and slid the mount between the engine box sides. This is a rendering of the mount.
Kingtec K45 TP Mount
The following 2 users liked this post by wfield0455:
Dansy (03-03-2022),
Neil Guildford (02-27-2024)
Kt 60tp
I just finished up a conversion on a Comp Arf Siai from gasser to TP. KT60 installed. Used CF to reinforce the firewall. constructed a mount from 1/4" ply and then fabricated aluminum reinforcements.
tmgreen64 (08-17-2022)
K30tp mount
Have you made up a mount for the k30tp? I'd like to mount one in a Legacy Bushmaster. Can't seem to find any mounting kits. You could probably make some money selling these kits.
This reply is for the person who made up the k45to plywood mount
Thank you
Dan Sears
Thank you
Dan Sears
